hi all, first thread here :D , although i have found this forum damn useful reading up about the YBR125..
anyhow, wanted to ask y'all a quick question.
the factory indicators on a ybr are 10w, according to the owners manual, but aftermarket ones, by oxford, are 21w..
would that be fine, considering its only a 11w increase, and bearing in mind that indicators aren't constantly on. also the wiring on the harness seems like it can handle it. :unsure:
any opinions? :unsure:
(btw, im changing to these, because ive got a set of spotlamps, and couldnt find anywhere to mount 'em - but the normal indicator positions - as a temporary fix, the indi's are cleverly mounted on using sellotape :lol: ) will post up pictures if anybody wants any ideas/inspirations (when bike gets back from mechanic) ;) ...
10w is unusually low for indicators, is this a haynes manual by any chance?
21W is the norm or you could go LED and use an LED control flasher
I think if you fit 21w bulbs your indicators may flash faster.
considering its only a 11w increase, ---------------------------------------------------------------------------------------------
Now then " iv just M.O.T."d The old 400 [passed. ] Point is it failed last week & one thing was "turn signals" Too fast [120 flash per min] is max .... so the options
1 . Fit another unit [ original is soldered 3 terminal] spare 1 had 2. :(
2 . replaced rear bulbs [ off RD400] 12 v /21w. DT400 is 6V/17w.
BINGO Slowed repetitions [ Increased resistence ] Rears were slightly dimmer but hey shes thru MOT.
NOW FOR THE REGISTRATION ... <_< HOPINGLY BY TOMMORROW NT. :rolleyes:
thanks for the quick response people :thumb:
drewpy, 10w is from the handbook, the proper yamaha one - clicky clicky for a link for the same thing - but as a pdf.. to the end (page 8-2 and 8-3)
id like to go LED, but really not too keen on spending too much :mellow: .. if they somehow manage to blink faster, i may need to get some sort of controller - then it'ld be time to go for LED's B)
:o thanks for that mate :thumb:
im MOT free for another two years (07 plate :icon_wink: ), but ill wire them up anyhow, without mounting them, and just count if its under 120 flashes/min :icon_biggrin:
@drewpy: "21W is the norm or you could go LED and use an LED control flasher"
The normal wattage is the one prescribed by the maker, and that is 10w for the YBR125
@Geoffxt: "I think if you fit 21w bulbs your indicators may flash faster."
Biger wattage = slower blinking (or flasher reley burned)
@uzzi_999
If you put LEDs on you should change the flasher releay 'cause LEDs need a special flasher (due to very low consumption) or a spesific resistance (in serial junction).
i tried fitting arrow indys a while back
and they didnt work at all
good luck in getting smaller indys.
what exactly was wrong with them?
