Neep Help on a CT3 & RT3
gfrench
This post is 5762 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hello everyone-
New to the forum and I am starting 2 Resto projects on a 1973 RT 360 Enduro and a 1973 CT3 175 Enduro.
I have just put new Fork seals in each bike and need to know how much fork oil to put in each bike.
Thanks in advance for any help.
Greg
RT 360 Enduro
Hi greg --welcome . The RT1 --360 HAS 210 CC[ 7.1fl oz] 10W30 grade oil in each fork ...
dt250/ 400 has 175cc [5.85fl oz] of the same grade
CT -175 ??? not shure . but if the same diameter / leanth .. prob the same [twinshock correct me :D ]
thank you for the info on the 360.
I will keep digging on the CT3 175 fork oil amount to see what I can find.
I am starting on the Oil pumps and need to set the gap- Seeing 0.20 mm for the 360 Is this correct?
Just took a loook at the CT3 175 and seeing it is at 0.27 mm? And sugestions on these settings? Seem correct?
Hi again ... RT 1 360 -DT250/400 , All work the same settimg [ 0.20-0.25] this shud equivilent to 32/1 ratio.
Duno about DT175 . but at 0.27 least its not too lean... ;)
Well good news--
I have the 73 Yamaha CT3 175 all back together- had the top end all redone and I put it all back together and Fired right up 2nd kick. Oil pump is working great!
All electrical is working except for the flashing of the trun signals- They light up but will not flash whether it is running or not.
Is this the flasher unit? Or do I have something wired wrong?
Thanks-
Well good news--
Thanks-
hey ! sorry to insert in this topic but does the 2 fork legs are identical? They all have exactly the same part in putted in the same way? because i've got problem with mine, which i dissasembled a few time ago and i can remember where everything goes and it seems that one piece is missing... I only have one cylinder cut on the lenght(similar to the one on the springs agaisnt the top bolts) part number 11 in this link
http://www.bikebandit.com/houseofmotorcycl.../m7053sch216345
Its not this one, i have those to but its more like number eight. Anyway, is this piece an important one( i think its when you bottom the suspension, the nner chrome leg wont be destroyed hitting the bottom, the little piece will. What do you think?
thanks!
