suspension tie rod lenght & ride hieght Fazer FZS600
Just bought a 2002 Fazer 600 FZS, and ride height seems a little lower than I remember from my last 2 of these, can anyone please help, what is the length of the standard suspension bottom "dogbone" tie rods? on mine they are 140mm from hole center to hole center, is this standard, or shorter than standard, I have a pair of standard ones from my old fazer thou and they are slightly longer, I wonder if the standard ones are the same from FZS 600 to FZS thou? Any help much appreciated, or someone measure their standard ones, dead easy to do, just need a tape measure, access is no problem, ta
Also can any say whether a hagon shock is good for the rear? Are they good quality and work better that standard?
