Is it possible to replace the oil sight glass on an xj900F ?
I have absolutely no idea, but as a suggestion, if the glass is on the reservoir then maybe just a replacement reservoir?
Hello. I don't know this engine well, but if its a derivative of what I have in my FZR600 I don't think so. I have a similar problem with the sight glass on my engine; the sight glass appears to be stained or discoloured which makes it very difficult to read the oil level properly.
If your's is like mine, it seems that its pressed into the right hand side casing when the casing was manufactured, and its not removable.
Cheers
Cheers
Cheers - unfortunately the glass got sand-blasted so is now opaque. Best I look for a replacement clutch cover methinks?
