January 28, 200916 yr when i take out the 2 stroke oil gauge in the bottle the red light comes on but when in as normal and i turn the key the test signal should light up and then slowly fade away it does not show test light when i turn the key anyone know what the prob might be??
January 29, 200916 yr when i take out the 2 stroke oil gauge in the bottle the red light comes on but when in as normal and i turn the key the test signal should light up and then slowly fade away it does not show test light when i turn the key anyone know what the prob might be?? you could have a prob with the gauge/sender (as it is duel function, most likley) or some cruddie earths on the wiring as I did very little with TZR250 I'm unsure Regards Jim
January 29, 200916 yr Author thanks for reply it turned out that the oil gauge is faulty apparantly the diode has packed up and in the depths of the unit so its a new one then!!!
