grinding nosie from motor
hi
my dt125x 07 is making a funny nosie like a grinding nosie from the motor
it's sounds fine when i start it and runs like a dream with no smoke
but when i am going along at eny speed and eny gear when i come of the revs
and pull in the clutch so im rolling along there is a on and off grinding nosie from the motor
eny one now ? :unsure:
Unless it's particularly loud, I wouldn't worry.
Most bikes make different noises when the clutch is pulled in.
I imagine it's the engine blasting off as it's suddenly got no load, ie you've removed the drive train.
Check and lube your chain, there's a good chance with all this crud around that its coming from there.
Adam.
  • 4 weeks later...
had this problem myself mate, make sure your chains not too slack and give it a good clean and lube.
Mine barely makes a noise now.
Tom
