January 28, 200916 yr hi my dt125x 07 is making a funny nosie like a grinding nosie from the motor it's sounds fine when i start it and runs like a dream with no smoke but when i am going along at eny speed and eny gear when i come of the revs and pull in the clutch so im rolling along there is a on and off grinding nosie from the motor eny one now ?
January 28, 200916 yr Unless it's particularly loud, I wouldn't worry. Most bikes make different noises when the clutch is pulled in. I imagine it's the engine blasting off as it's suddenly got no load, ie you've removed the drive train.
January 28, 200916 yr Check and lube your chain, there's a good chance with all this crud around that its coming from there. Adam.
January 28, 200916 yr Moderator +1^^^^^^^^^^^^^^^^^^^^^^ Check and adjust chain slack as per spec for your bike, and give the chain a good lube
February 22, 200916 yr had this problem myself mate, make sure your chains not too slack and give it a good clean and lube. Mine barely makes a noise now. Tom
