January 26, 200917 yr is there any way that i can make my dt 50 front suspension any harder as it is very soft an rather horrible
January 26, 200917 yr Moderator is there any way that i can make my dt 50 front suspension any harder as it is very soft an rather horrible You can drain the oil and use different viscosity (thicker) oil in them, get youself a manual the info will no doubt be in there.
January 26, 200917 yr Author You can drain the oil and use different viscosity (thicker) oil in them, get youself a manual the info will no doubt be in there. thanx an i will do that today
