1969 dt1-b
Hi,
Open to suggestions on what combination of sproket sizes would be best for a 1969 yamaha dt1-b 250 which will be used on the road only, Thanks for any info. shared.
Hi,
Yamaha offered many different final drive ratio's. Counter shaft sprocket's from 13t-16t, and the rear from 40t-51tT.
The higher number of teeth on the rear sprocket will raise the ratio # The bigger the rear sprocket you lose top end speed but gain torque. It is the opposite on the countershft sprocket. Alot cheaper to work with the little sprocket.
