January 22, 200917 yr Hi, Open to suggestions on what combination of sproket sizes would be best for a 1969 yamaha dt1-b 250 which will be used on the road only, Thanks for any info. shared.
January 23, 200917 yr Hi, Open to suggestions on what combination of sproket sizes would be best for a 1969 yamaha dt1-b 250 which will be used on the road only, Thanks for any info. shared. Yamaha offered many different final drive ratio's. Counter shaft sprocket's from 13t-16t, and the rear from 40t-51tT. The higher number of teeth on the rear sprocket will raise the ratio # The bigger the rear sprocket you lose top end speed but gain torque. It is the opposite on the countershft sprocket. Alot cheaper to work with the little sprocket.
