sparkplugs
after two days of sorting my carb out,i found out my new sparkplug was a dud.
which,makes me think what are all the numbers and letters on the plugs.
and why when the plugs look the same.
Youre unlucky to get a new dud plug, cant happen often. The numbers a a manufacturers code for heat range thread size and length etc, Why what?
I know where i like to stick there plug,up there ngk.
Aye russ -- like O,git. says its running temp diffrence"s i,e. NGK 2411 B8ES ----RD400
NGK 2611 B9ES-----DT400
Both are identical lenth [thread] +gap. but will operate at diff temperature ..
If it's of any help, I can recommend Bosch plugs :D
thanks for all your info,i shall remember to check plug first.
