January 20, 200917 yr Hello I have a yamaha BWs 50 it was running fine a few days ago but now it bogs down or cuts out when you pull away but if the choke is half on it runs ok. I have checked the plug,reeds,manifold for leaks and adjusted the mixture. can anyone give me some help thanks
January 20, 200917 yr That's the new Scoot stroker isn't it? You may have a dodgy HT lead. For a few £s or $s, it would be well worth picking up a new one - handy as a spare if nothing else.
January 20, 200917 yr Moderator Hello I have a yamaha BWs 50 it was running fine a few days ago but now it bogs down or cuts out when you pull away but if the choke is half on it runs ok. I have checked the plug,reeds,manifold for leaks and adjusted the mixture. can anyone give me some help thanks Sounds like either water in the carb or a blocked pilot jet, either way its a carb strip and clean.
January 20, 200917 yr Author Sounds like either water in the carb or a blocked pilot jet, either way its a carb strip and clean. hi thanks I will clean the carb. I forgot to say if you go along at just over half throttle the put full throttle on the engine dies for a few secs then picks up
January 20, 200917 yr Ah! Sounds like a fuelling issue if it's bogging down when you rip open the throttle. Too much fuel and too little air. You could try a K&N (OE style) air filter to increase air flow.
January 20, 200917 yr Author the mixture screw on the carb adjusts the air mix if I screw it in will that make it run richer or leaner
January 20, 200917 yr Moderator the mixture screw on the carb adjusts the air mix if I screw it in will that make it run richer or leaner If it is an air mixture screw, ie on the filter side of the throttle slide, then screwing it in will make it richer However, if it is a fuel mixture screw, ie on the engine side of the throttle slide, then screwing it in will make it leaner
