I just bought an oil pump off eBay that fits a CT2/3, but it has a larger worm drive pitch than the bad one I'm replacing. Other than that they are identical. Any help or information would be appreciated...
Risky, I would not use that pump yet. The output could be more or less than required for you engine. Let me see if I can find the output volume and then you can install the pump and check it. Maybe you can adjust the pump stroke to suit your needs. If it was me I would probably send that pump back. The pump housing was used on many models.
