Another Electronics question
Hi everyone.
im getting myself a little satnav and would like it to be able to charge from my bike whilst im riding.
i can use the satnavs' mini USB port to supply the power (5Vdc), and because maplins sell the individual connectors i can make an adapter without much of a problem.
BUT.
my bike uses a 6V regulated supply for the indicators and brake light, would i be able to run a second wire from the Positive terminal on my 6Vdc battery, drop it through a 5Vdc regulator to the USB plug and then run a common ground from the USB plug and the regulator to the negative terminal on the battery, with an on/off switch on the handlebars
i was aiming for a 0.5 amp draw, which should be okay as my haynes manual indicates the charging current is a minimum of 0.8A (lights on @ 3000RPM) up to 2.0A (lights off @ 8000RPM)
any advice would be appreciated :)
Steve
that should work fine, in fact its a great idea as the bike is 6volt. any of the 1-1.5amp voltage regualtors would work and should provide a rock steady 5 volts to drive the sat-nav.
id use something like this:http://www.maplin.co.uk/Module.aspx?ModuleNo=10529
Lol, great minds think alike, i was just on the maplins website as i drew up that little schematic.
quick blast up to andover tomorrow then to go shopping for some parts :)
