fazer 600 year 2000 bleeding rear caliper
rear caliper getting fluid through canot get pressure no leaks.new seals and goodridge fitted was working before replaced seals 'master cylinder appears ok .have bled brakes before no probs.help
Check the Banjos have not got any swarf in them restricting the flow of fluid.
system is spotless seals ok.pumped 500mils fluid through. reverse bled system canot get pressure.bleed valves not leaking
  • 4 months later...
I had a similar problem a few days ago when I replaced rear brake line. It took me a while to realise that there are two bleed nipples on the rear caliper, one at the front and one at the back.
