Posted January 15, 200916 yr Hi all, I recently bought an xt 600, and found that the lhs engine casing is either from the wrong model or is missing a part of a cover. The hole is shown here, in between the two wires, left of the barrel. it's the side you can see from the picture, and it was open, but had a plastic bung there. I presume there is meant to be some sort of seal there? Cheers Pyro
January 15, 200916 yr Author Ok, I've just realised the starter motor is what's missing there. DOH Does anyone have any ideas how I could 'plug' this hole more efficiently, or where I might find a starter motor. Cheers Pyro
January 15, 200916 yr you could try a motorcycle breaker for a starter motor or eBay. if you are handy in a workshop you could make up a little plastic bung using a lathe and cut a thread in it with a dye, thus making a little removeable plastic bung
January 16, 200916 yr Ok, I've just realised the starter motor is what's missing there. DOH Does anyone have any ideas how I could 'plug' this hole more efficiently, or where I might find a starter motor. Cheers Pyro I've been looking at this picture for ages, wondering where the hole was... did, think you ment the starter motor mount! anyway, the XT600 motor is the same as the TTR600E, there was a bloke on ebay a couple of months ago selling the bits off his. I have a workshop manual for the TTR on PDF, I'll not be back till Monday (and I'll forget!), but if you send me a PM I'll put it on the www and send you the link. if you want to fit an electric start at least you'll have a wiring diagram !!
April 3, 200915 yr help me, im new member i cant open new post, i nead CDI for my yamaha XT600, 1984., 43F. offers on : [email protected] THANK YOU ALL !!!
