the beast Posted January 12, 2009 Share Posted January 12, 2009 i just cant get the timing right . anybody that knows how to set it 100% right Link to comment Share on other sites More sharing options...
Moderator drewpy Posted January 12, 2009 Moderator Share Posted January 12, 2009 Not me, but there is the thumper club and an XT/SR club!!! Link to comment Share on other sites More sharing options...
Moderator YamaHead Posted January 12, 2009 Moderator Share Posted January 12, 2009 As a suggestion....you could post an inquiry HERE Loads of XT500 knowledge to be found. Link to comment Share on other sites More sharing options...
Moderator Airhead Posted January 12, 2009 Moderator Share Posted January 12, 2009 Plug Type NGK BP - 7ES Plug Gap 0.7 - 0.8mm (0.028 - 0.032in) contact breaker gap 0.3 - 0.4mm (0.012 - 0.016in) The points gap is set at the widest opening. Removing the large plug just left of and below the points reveals the timing mark. The contact breaker points should be set so that they are just opening as the F mark aligns with the pointer Link to comment Share on other sites More sharing options...
the beast Posted January 13, 2009 Author Share Posted January 13, 2009 thanx alot guys il definatly try it out Link to comment Share on other sites More sharing options...
