January 12, 200917 yr Moderator As a suggestion....you could post an inquiry HERE Loads of XT500 knowledge to be found.
January 12, 200917 yr Moderator Plug Type NGK BP - 7ES Plug Gap 0.7 - 0.8mm (0.028 - 0.032in) contact breaker gap 0.3 - 0.4mm (0.012 - 0.016in) The points gap is set at the widest opening. Removing the large plug just left of and below the points reveals the timing mark. The contact breaker points should be set so that they are just opening as the F mark aligns with the pointer
