January 11, 200917 yr newbie need help.need replacement aftermarket airfilter,anyhelp out there. any ideas on needle and size jets.bike ticks over nice,runs like its on choke. just got bike and t came with a small shape cone airfilter not standard.
January 11, 200917 yr Author I thought i already gave you this infoyes,thanks you did.i need standard filter which i have not got.
January 11, 200917 yr Moderator Maybe the needle jet is worn they can wear oval which will make the bike run rich, have you stripped down the carb and noted the jet sizes and id markings and needle clip settings as is? Examinne the needle jet opening using a magnifying glass and also the needle, look for wear
January 11, 200917 yr Author yes,thanks you did.i need standard filter which i have not got.i will strip the carb down,and note with the invo you gave me. thanks for your help,let you know the outcome.
January 11, 200917 yr Moderator i will strip the carb down,and note with the invo you gave me. thanks for your help,let you know the outcome. On the subject of carbs, you may find this useful Here
