Hi all
I'm in the process of rebuilding an XT350 as is a mate and he is stuggling with the front caliper for his (i.e. he hasn't got one).
We tried fitting my caliper to his to check it was trhe same but is doesn't fit, we also tried a TT350 caliper that I bought thinking it would fit straight on mine (anybody need one???? let me know) and this also doesn't fit as the fixing lugs on his fork leg are much farther apart than on mine. The fixing bolt centres are about 100mm apart on his forks.
Any body any ideas what might fit??
Cheers
If all else fails, try giving Laurence a call at J&L in Carlisle.
  • 1 month later...
  Gas up - Let said:
If all else fails, try giving Laurence a call at .
hi
i have fitted xt 350 forks to my dt 175,dt lc caliper fitted straight onto xt forks.
