Can anyone please shed some light on this! :angry:
I just got my first R6, it is a 2000 bike with only 7500 miles on it.
The bike cuts out when kicking down gears and stopping, the revs drop and it stalls, checked the norm things like plugs and filters, both fine.
The pick up on the throttle is spot on and it runs lovely when ticking over in stand, ride it down the street and stop at the end the revs will dip and the bike will cut out.
It starts no problem and your ok till the next time you have to slow rite down.
Any help would be great.
My guess would be the carbs need a clean and mixtures adjusting.
alredy checked the carbs and there not sticking what else could be wrong with them?
do you think bleeding them would help?
Have you checked the jets are clear? Also check the fuel filter in the tap under the tank and for any split fuel lines.
At higher revs any problem will be less noticable because of the higher fuel flow.
i think i have water in my carb float bowls how would i go about draning these.
thanks
I check the fuel filter and pipe work, all fine.
is that how you drain them just with the plugs.
did not want to play to much, not to srue what i am fiddling with.
What is the best way to get into access it?
should i remove all the plastics?
all help is good help.
YAaaaaa
that is very useful thanks will have a go tommorrow.
hope that is what it is.
cheers
:lol::lol::D:D
Bleed the float balls and reset the throttle position and it is running a dream.
HAPPY DAY'S
