hi all im new to this forum, im jus having ago at de-restricting my bike, ive took the tank and airbox off and am now trying to remove my carbs...is it true i need to totaly remove them? any help would be appreciated i cant acutaly see how to remove them
what do you mean de-restrict an r6? they are not restricted.
he is probally on the 33bhp restriction
There are different ways of restricting the R6.
You may have washers in the exhaust ports, in which case all you need to do is remove the headers from the block and prise them out.
Or, you may have carb slide restrictors. If this is the case, you will need to remove the restriction bolts on the carb slides.
i have washers restricting the air flow, i can see the washers all i need to do is find out how to remove the carbs as the washers are sat underneath them
