Posted January 2, 200916 yr Hi All Im new to this biking stuff so hope someone can help me with this, i have a Thundercat 600R and after a hard ride out the engine was noisy, when i start the bike cold it puffs exhaust smoke out fro mthe front of the bike someware, is this a common problem or just a knackered gasket someware. Please help Thanks John
January 2, 200916 yr Oil level? When was the oil last changed? Cats can burn oil, like the Aces. The only way to solve the problem is to fit oversized piston rings. As it is, it is not a major issue, but keep an eye on the oil level. A pint every 1000 miles is not uncommon. Also, check the exhaust clamps and downpipes. You may have a hole and/or leak.
January 5, 200916 yr Author Oil level? When was the oil last changed? Cats can burn oil, like the Aces. The only way to solve the problem is to fit oversized piston rings. As it is, it is not a major issue, but keep an eye on the oil level. A pint every 1000 miles is not uncommon. Also, check the exhaust clamps and downpipes. You may have a hole and/or leak. I will check them as soon as i get infront of it in the light, i could be oil then coz havent put any in since the service in April, oops. To check the downpipes i will have to take the ferring off as i dont have a socket to squeeze in between the rad and the engine, Thanks for your help
