Posted December 28, 200816 yr Hello, My Yamaha TZR 50 cuts out when i put it into gear, it starts fine in neutral and when i put it into gear it cuts out, does anyone know what the problem is? and how it could be fixed? thanks in advance
December 28, 200816 yr Hello, My Yamaha TZR 50 cuts out when i put it into gear, it starts fine in neutral and when i put it into gear it cuts out, does anyone know what the problem is? and how it could be fixed? thanks in advance might seem a silly question but is the stand down as some bikes have aside stand switch which if you put it in to gear and the stand is down it will cut out
December 28, 200816 yr Author might seem a silly question but is the stand down as some bikes have aside stand switch which if you put it in to gear and the stand is down it will cut out no the stand is up, it just feels when you put it into gear that the wires are cut and it just loses power straight away
December 28, 200816 yr Moderator no the stand is up, it just feels when you put it into gear that the wires are cut and it just loses power straight away Sounds like the side stand switch, have a look at the connections, maybe one has come adrift
December 28, 200816 yr Author Sounds like the side stand switch, have a look at the connections, maybe one has come adrift it can't be that because when i flick the stand up its fine, its only when i put it into gear, the second my foot presses down on the gears
December 28, 200816 yr it can't be that because when i flick the stand up its fine, its only when i put it into gear, the second my foot presses down on the gears when you put your bike in to gear with the stand down it will cut out but it the switch thing on the stand is broke it obv wont work just get it in to a local garage if you dont no wot your doing lol
December 28, 200816 yr Author when you put your bike in to gear with the stand down it will cut out but it the switch thing on the stand is broke it obv wont work just get it in to a local garage if you dont no wot your doing lol it's nothing to do with my stand, my stand doesn't have a switch sometimes ive rode my bike with my stand down and it flicks back up and runs fine so what could it be?
December 28, 200816 yr Moderator it can't be that because when i flick the stand up its fine, its only when i put it into gear, the second my foot presses down on the gears the side stand switch isnt working, as i said look for a loose connection!! if there arent any loose connections try disconnecting it and short it out somehow
December 28, 200816 yr it's nothing to do with my stand, my stand doesn't have a switch sometimes ive rode my bike with my stand down and it flicks back up and runs fine so what could it be? ermm well only thing i can think is ya gear box isnt running right . also try checking your clutch !
December 28, 200816 yr ermm well only thing i can think is ya gear box isnt running right . also try checking your clutch ! if its none of them id try just puting the bike in 2nd gear hold the clutch in n push it n let the clutch out see it gos like that mate other than that i really dont no lol
December 29, 200816 yr does the bike clunk when put into first gear and jump forward then cut out mate ... daz
