**Help** TZR50 Cuts Out When Started **Help**
Sam Swann
This post is 5797 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hello,
My Yamaha TZR 50 cuts out when i put it into gear, it starts fine in neutral and when i put it into gear it cuts out, does anyone know what the problem is? and how it could be fixed?
thanks in advance
Link to comment
Share on other sites
Hello,
thanks in advance
might seem a silly question but is the stand down as some bikes have aside stand switch which if you put it in to gear and the stand is down it will cut out
Link to comment
no the stand is up, it just feels when you put it into gear that the wires are cut and it just loses power straight away
Link to comment
Sounds like the side stand switch, have a look at the connections, maybe one has come adrift
it can't be that because when i flick the stand up its fine, its only when i put it into gear, the second my foot presses down on the gears
Link to comment
when you put your bike in to gear with the stand down it will cut out but it the switch thing on the stand is broke it obv wont work just get it in to a local garage if you dont no wot your doing lol
Link to comment
it's nothing to do with my stand, my stand doesn't have a switch sometimes ive rode my bike with my stand down and it flicks back up and runs fine
so what could it be?
Link to comment
the side stand switch isnt working, as i said look for a loose connection!! if there arent any loose connections try disconnecting it and short it out somehow
Link to comment
ermm well only thing i can think is ya gear box isnt running right . also try checking your clutch !
Link to comment
if its none of them id try just puting the bike in 2nd gear hold the clutch in n push it n let the clutch out see it gos like that mate other than that i really dont no lol
Link to comment
  • Recently Browsing
