Posted December 22, 200816 yr Hi to all Does anyone know where I can get a cdi stator coil for a 1983 yamaha DT100. Mine is completely bad and I couldn't find anything on ebay. I picked up the bike for $100 not running and I'm working my way through the problems. As an alternate does anyone know what the voltage is that comes from the cdi stator coil. Maybe I can build a circuit to supply the necessary voltage from the battery. JoAnn
December 22, 200816 yr If your not worried about lights a points CDI is pretty easy to hook up. These are more readily available. I had the same problem with a DT400.
December 22, 200816 yr Check bikebandit.com. They have a huge inventory of parts, and I think that they would have a ton of part for that bike. It is also really easy to use and all of the parts are OEM directly from Yamaha. Hope this helps. Baseballpro3112
December 23, 200816 yr Author Hi Where can I find a points set up. Bike bandit doesn't have the part for the pulser cdi
