December 20, 200816 yr Hi everyone. Would like to add a rev counter to my DT50MX like they do on some of the RD50s' and was told the DTs' block was machined to take the rev counter drive but just didnt have the attachment nescessary to do so. so, where abouts can i find the rev counter drive on the engine block? (pics would be helpful) regards Steve
December 21, 200816 yr Hi everyone. Would like to add a rev counter to my DT50MX like they do on some of the RD50s' and was told the DTs' block was machined to take the rev counter drive but just didnt have the attachment nescessary to do so. so, where abouts can i find the rev counter drive on the engine block? (pics would be helpful) regards Steve Hi Steve there should be a rubber bung on the top of the crankcase, this is were the drive fitted on the RD motors but fitting the clock my look a bit unsightly (unless you can obtain a complete set of clocks from the RD50mx, which may just fit in your headlamp cowl) Regards Jim
December 21, 200816 yr Author if i can find a small rev counter, even just an aftermarket one that clamps onto the handlebars i wouldn't mind. is that the rubber bung towards the back on the right hand side of the engine?
December 21, 200816 yr Author oh, and what/where is the red line on the RD/DT50MX engines?, says in my Haynes manual that the RPM Peak is at 4,000 RPM, but that probably isnt at the red line.
December 22, 200816 yr oh, and what/where is the red line on the RD/DT50MX engines?, says in my Haynes manual that the RPM Peak is at 4,000 RPM, but that probably isnt at the red line. The bung at the rear right is correct, the RD50M & MX red lined at 10k but in stock UK trim the bike would not rev over 6k but I did get a couple to rev to 8k with some mods Regards Jim
December 23, 200816 yr Author this has had a bigone exhaust and expansion chamber and also a performance air filter so i would probably have thought it will rev a bit higher now that i have opened up its airways a little. many thanks for your help, will look into finding myself an RD50 speedo cable and rig one up in the new year
December 23, 200816 yr Moderator this has had a bigone exhaust and expansion chamber and also a performance air filter so i would probably have thought it will rev a bit higher now that i have opened up its airways a little. many thanks for your help, will look into finding myself an RD50 speedo cable and rig one up in the new year big bore doesn't always mean higher rpm as there is more reciprical weight to throw up and down in the bore. if anything it would be safer to keep the revs down rather than risk blowing up the engine!! I know 50cc racers get to 18,000- 20,000 rpm but that is for 1 race
