oil light
hey guys can u help me out my oil light comes on a it wont turn off i was reving my bike in the garage reved it up to 8000 and the oil light just come on and wont turn off there is engine oil and 2 stroke oil and when i rev it i can smell 2 stroke someone help cheers luke!!!!!!!!!!!!! :twisted:
Sounds like your 2 stroke sensor has failed
Check your connections
does it go off when in gear mate? i'm sure some of them were meant to have the light on in neutral(so you knew if it worked) and went out once in gear. if i'm talking bollox it could just be the switch :D
all 3 of my dtrs done that
ginger minge they should go off when you put it in gear if they nit it will be a loose connection or faulty sender or more in depth oil problems
