DT 50 MX wont run right
Hi all
My son has put a Big One exhaust and a performance air filter on his DT 50 MX but when it gets past half throttle the engine bogs down.
I think it might be the main jet that needs increasing in size, if I'm right any ideas where I can get one?
Any help appreciated
Cheers
BABB
Hi all
Cheers
BABB
Yes you will need a bigger main jet, find out what size it is now,... and then try you local yamaha dealer, or Fowlers in bristol, or have a word with Steve Here
the stock DT50MX jet is 82, most likely fitted with the Mikuni carb.
jets are available from www.bitzforbikes.co.uk, www.motorcarb.co.uk, have a quick search on the internet and you should find plenty of suppliers :).
mine is running a Bigone exhaust, expansion chamber and a K&N style filter, at the moment i think it is running a 90 or 95 size jet... will be putting a big bore kit on it soon so will probably go up to 110 or around that area
if your not planning to big bore it or play with the carb/reeds/induction then i would think a 95 is the way to go :)
- Steve
P.S. what year is your DT?, mine is a 1990 so aslong as yours is 87-93 it should be the same spec
