1980 xs850
well i messed up
I was tightening my tensioner just as the book said
took tensioner cover off
turned engine counter clockwise a few times
till the plunger stuck completly in
then tightened the adjuster bolt and lock washer
turned it over and the plunger moved in and out again
i think the chain slipped timing marks do not line up no more under the left cover
also the engine is locked it will not turn no more
you can turn it back a little and then forward to the same point
i think my valves shot down on top of the piston
shouldnt have hurt anything as i turned very easily and did not hunker down on her
just what should i do now
all help is well appreciated thanks alot
christopher
1980 yamaha xs850
Sounds like thats what happened to me too (chain slipped), youre going to have to relieve the tensioner , undo the chain link and re-time as per workshop manual before re tensioning, like drewpy says...hopefully you were turning it over by hand or kickstart lever!
I was turning it over by hand
thats what ill do then thanks alot
  • 2 years later...
I recently bought a 1980 XS850 and it appears that the previous owner had the same problem. He must have used the starter though... bent Exhaust valve in cylinder #2..... unfortunately.
