flasher unit
The flasher unit on my sr 125 has packed it in. So went into halfords etc today but they dont have any. There plenty of 21w flashers but mine is apparently 10w x 2 +1.7w. Is there an alternative one i could use?
Hi Stevie,
10 x 2 +1.7 = 21.7w, 21w unit should work but most m/c shops hold a universal (2 or 3 pole) can that will do what you need (it does 8w ~ 21w) but ensure you buy a 12v or 6v one as you require. If I remember correctly SR125 was always 12v but I'm sure someone will have a 6v one !!!
Regards Jim
Brilliant. Cheers jim! I'm hopnig its going to be nice-ish tomorrow so i can go out and check my valve clearances etc. Got the email you sent me printed off so i can give it a bash!
