Posted December 9, 200816 yr im going to respray the fuel tank, But dont know the exact paint colour, Its a 1996 yamaha sr 125, dark green. Is there a specific paint code? Whats the closest match i could get
December 9, 200816 yr Original paint codes are no good if its ever been resprayed a different shade at some point. Easiest thing will be to t-cut a part thats painted and take it to paint shop to have a match made up. These days most halfords stores are able to do good colour matches using an 'electronic eye' tool which shows them how to match the colour.
December 10, 200816 yr Author Original paint codes are no good if its ever been resprayed a different shade at some point. Easiest thing will be to t-cut a part thats painted and take it to paint shop to have a match made up. These days most halfords stores are able to do good colour matches using an 'electronic eye' tool which shows them how to match the colour. Cheers. It hasnt been resprayed, But i'm wanting to respray it as the fuel tank is not in the greatest of conditions. I'll nip down to my local halfrauds!
May 17, 200916 yr Similar question here about the same colour paint.. Halfords informed me that normally they don't just match the paint, they start with a manufacturers code to find out about metallic etc and then match it further if needs be.. So, is there a list or source of paint codes anywhere that anyone has come across? Mine is a dark green 1994 SR125 and I know the paint is almost completely the original colour as it's been stored in a garage since 1996, with 850 miles on the clock! Cheers James
August 15, 201015 yr Similar question here about the same colour paint.. Halfords informed me that normally they don't just match the paint, they start with a manufacturers code to find out about metallic etc and then match it further if needs be.. So, is there a list or source of paint codes anywhere that anyone has come across? Mine is a dark green 1994 SR125 and I know the paint is almost completely the original colour as it's been stored in a garage since 1996, with 850 miles on the clock! Cheers James
August 15, 201015 yr it is worth trying this company out www.rsbikepaint.com they have a vast array of paints but also have at tool to tell you what the paints are for the moddel and year.
August 15, 201015 yr Moderator ....but also have a tool to tell you what the paints are for the model and year. yep, he's called Kevin
August 16, 201015 yr it is worth trying this company out www.rsbikepaint.com they have a vast array of paints but also have at tool to tell you what the paints are for the moddel and year. Is that the place in Barnsley ? I've heard they are very good Last I heard, they have a lady there called Renata ? who is VERY helpful Em
August 25, 201015 yr www.cmsnl.com have a list of Yam paint codes, but you need to identify the green
