Oil Leak 96 XJ 600 Seca II
Is anyone familar with the technical service bulletin for weeping oil from the engine bots?
I thought i might have blown a head gasket but it could be leaking oil from this bolt.
I'm sure someone has ran into this before so any help or thoughts would be appreciated.
No I'm having a different issue but thanks.
I pulled the engine and when i look at the fron of it by the exhaust ports I can see dryed up oil that appears to be traveling up from the bottom of where the bolt is fitted.
I going to pull the bolts and hit them with some high temp. bolt sealant.
I'll report back might take a while though.
Have you checked all your breather pipes for blockage? Even transfer ports within the engine can get blocked. All of these will cause pressurisation and weeping bolts.
