52 plate jogR
Hi all
I have a Yamaha Jog R on 52plate (2002 UK)
The speedo dosent work and guy at garage says it could be the speedo sensor in the front wheel but cant find anything to read to enable any help to fix.
Please if you can help i would appreciate it.
this moped has a speedo cable from the sensor in the front wheel which leads to a black plug from which two wires carry on to the speedo dial.
This is why im having problems sorting it out as it is not in the service manual i have.
The model of this moped is a Yamaha Jog R CS 50
No sorry i meant a cable that spins round and turns the inside the speedo (old school), not familiar with yours, it must be some sort of pulse counter device, all i can say is check the cables for continuity with a multi meter and make sure the cable plugs are clean and connected properly and that the sensor is seated correctly, not loose etc! also check is there a fuse for the speedo.
