XT350 Brake Calipers
I've got a 1985 xt350 That needs a new brake caliper. I'm having a lot of difficulty finding a used one, and am wondering what if any other yamaha models use a brake caliper that is interchangable. Or, if anyone can share a source of cheaper aftermarket calipers.
Thanks.
I tried the same and couldn't get much help anywhere, but here's a tip, the caliper on a TT350 is not the same. The mounting lugs on the fork leg are slightly further apart. I found out the hard way by buying one on ebay, got the master cylinder and braided hose with it as well so it wasn't all bad.
Good luck
Hoggy
  • 1 month later...
Thanks.
Hi, I think endurospares on ebay has got one, but might be new and more than you might want to pay - but hassle free. Cheers;)
