Virago 535 1992
Hi there, the problem with my 1992 535 is that when you decelerrate then rev back up it seems as if I have fuel starvation.Say I'm cruising along at about 50mph then slow down and gear down for a junction, when I accelerate away from slowing down it takes a few seconds to catch up. When it started it wasn't too bad but it seems to have got progressively worse.Yet there are no problems when riding at up to 80/90 mph so fuel is getting through it only happens when I throttle off and then throttle up again.Any ideas
:mellow::huh:
Ok been having a thought and a scout round the net and have come up with the idea that perhaps it may be due to worn diagphrams
:mellow::huh:
Well Ihavent had a chance too try and sort out this problem as yet, but after talkin to a chap at work and explaining the problem, he reckons it may be a vacumning problem
sounds to me like it is bogging down with fuel when going from throttle open to closed, your theory may well be correct.
strip the carbs down and have a look-see, deffo sounds like overfueling to me though
