sr125 headlight
Hi all
I recently bought a 1999 SR 125 , but the headlight on it is massive and not the size I've seen on other SR's
can any one tell the diameter it should be so I can order a new one
Cheers
Hi all
Cheers
Hello tiggercat, i'll just go and check for you...
Right, here are somw appprox. measurements.
The chrome globe mounting for the haedlight is about 175mm dia.
The circular frame that sits inside this (as adjusted by the 2 screws for beam height) is about 160 mm
Dunno wot yours looks like, but the front unit onmy bike is a chrome wire framework that holds not only the headlight but also the turn lights (indicators) too, so I'd be wary of messing about wiv that!
Good luck NE way.
J
That sounds the same as mine, cheers for the info now i can go and order one
