back brake
gingerluke
This post is 7425 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
i went to put some new brake pads in and someone put the piston in the wrong way round i got it turned around and put the new pads in ive pumped the brake and nothin happens ive pumped it about a 100 times and nothins happening can anyone help cheers luke :roll:
I know this might sound a bit obvious, but you did replace the brake fluid after you had the piston out did'nt you?
  • Admin
Sounds like trapped air, rebleed the brakes :roll:
hey ginger minge if it is adt you are riding then one of the pistons are meant to be the opposite way to the other i went through absolute hell to find that
  • Admin
Yep in the DTRs the hollow end of the piston faces out, for some strange reason :roll:
