yammy majesty 400 running problem
Hi guys hope someone can advise me. I have a 6 month old majesty 400 on a ride to work in the cold the other day it took on a mind of it's own and when you shut off the throttle an decelerated it was ok down to about 2500 revs about 25mph then ACCELERATED moderatley up to 3000revs then back down to 2500...etc. At other road speeds it seemed ok and at the end of the ride the engine management light lit up just as I arrived at work. It actually climbed the small 50 metre hill outside the workplace on its own!! It behaved the same hot or cold. After work the bike seemed fine with just a littlle hesitancy in decelerating once again at 2500. It seemed to hold it's speed for about 5 secs or so before continuing to decelerate. Since then it doesn't seem to 'slow down' with the throttle off as it used to (ie engine braking) & I seem to be using the brakes alot more.
I was curious if a 'sensor' had developed a fault and figured the fitter could plug in a computer gadget to detect the fault (as the managment light had lit) but he says no!!
Any ideas?
thanks guys
Hi dont know owt about them, but for what its worth, check your throttle cable, is there water in it thats freezing and making it stick, or is it going rusty etc, i would disconnect it and buy one of those lube gadgets
