Poss gear problem
As you know (from all my unitelligent posts) i've been workign away at the bike. Seems to be having what i think is a bit of a problem. When i was in the garage today i was checking to make sure it was selecting gears. With the engine off. I can feel a definite change when i select 1st, 2nd and 3rd, But if i go to take it up again, it feels like nothing, Is that a problem or would it normally do that? Is there anything i'd maybe need to adjust to sort it?
No that could be normal, without rocking the bike back and forth, you wont be able to select all the gears.
Heres hoping then. When i had it out, i wasnt going fast enough to go above 3rd gear :)
even just by rocking it you should be able to select all of the gears in turn, if you can't then this may indicate a gearbox problem
I didnt try rocking it to be honest. I take it i just push it back and forth, turn the back wheel slightly?
yeh aslong as you move it in a way that the chain is turning the gearbox it should engage all gears
Great, I'll give it a wee try when im back at the garage. i was concerned as i had disconnected the clutch cable for removing the engine last week
