The Bleed nipple has sheered off the brake caliper! luckily, (or not) it has done it in such a way that the plug is still intact, however i think it will be a tough job to remove it! Anyone now what size it is, and also a way of going about removing it?
you can get "bleed nipple banjos" which will still let you bleed the caliper as long as the broken nipple still seals.
try M&P
