November 22, 200817 yr Hi Am in desperate need of some information regarding the Yamaha Enticer 125cc..... I have recently bought the bike with the intention of fixing it up as a bike to learn on,,, but i have found out the bike was made in India, and no one in the UK can give me any advice on parts, as most have never even heard of it. The bike has suffered some front end damage and new forks and wheel are needed...... Question..... Is there another bike that has the same fork measurements... My yolk size is 30mm hole and 185mm centres, the yolk stem is also 30mm. It may be possible to buy a complete front end from another bike if the stem is the same size,, i was told the virago xv 125 may be the same,, is this true????? Any info however small may be of some use to me Cheers Terry
November 23, 200817 yr I would sugest possibly posting a couple pictures of it, as it may have been sold somewhere else under a different name. In the US a Yamaha Enticer was a snowmobile lol.
November 23, 200817 yr Hi Am in desperate need of some information regarding the Yamaha Enticer 125cc..... I have recently bought the bike with the intention of fixing it up as a bike to learn on,,, but i have found out the bike was made in India, and no one in the UK can give me any advice on parts, as most have never even heard of it. The bike has suffered some front end damage and new forks and wheel are needed...... Question..... Is there another bike that has the same fork measurements... My yolk size is 30mm hole and 185mm centres, the yolk stem is also 30mm. It may be possible to buy a complete front end from another bike if the stem is the same size,, i was told the virago xv 125 may be the same,, is this true????? Any info however small may be of some use to me Cheers Terry yes the yamaha enticer is from india try googling it there is a lot of information out there Type: Single cylinder 4 Stroke, air cooled Displacement: 123.7cc Max Power: 11bhp@8000rpm Max Torque: 10.4Nm@6500rpm Bore x Stroke: 54.0 x 54.0mm Compression Ratio: 10:1 Power to weight: 94.83bhp/ton Idle Speed: 1300-1500rpm Carburettor: Ucal Mikuni VM20SS Air filter: Wet type element Oil Filter: Wire mesh type Ignition: CDI Starting: Kick Clutch: Wet multi-plate Gearbox: Four speed Primary Reduction: 3.579:1 Final Reduction: 3.133:1 Gear Ratio kmph/1000rpm 1 2.750 3.658 2 1.688 5.959 3 1.200 8.383 4 0.913 11.018 Kerb Weight: 116kg Max Payload: 130kg Wheelbase: 1380mm Length: 2090mm Width: 790mm Height: 1125mm Ground Clearance: 140mm Fuel Capacity: 13.5litres Reserve: 2.5litres Battery: 12V 2.5A Headlamp: 12V 35/35W Chassis: Diamond frame Front Suspension: Telescopic fork Rear Suspension: Swingarm with coil spring and oil damper Tyres Front: 90/90 - 17" Front: 90/90 - 18" 4PR Rear: 130/90 - 15" Rear: 120/80 - 16" 4PR Brakes Front: 230mm discs Front: 130mm drums Rear: 130mm drums Rear: 130mm drums Performance 0-60kmph: 7.2sec 0-60kmph: 8.4sec 0-80kmph: 12.6sec 0-80kmph: 16.9sec 0-400meters: [email protected] 0-400meters: [email protected] Roll On 3rd 4th 5th 30-70kmph 9.5 13.2 15.4 40-80kmph 9.9 13.4 15.9 Roll on 3rd 4th 5th 30-70kmph 11.1 16.1 - Braking (60-0kmph): 23m/2.9sec Top Speed: 97kmph Fuel Efficiency Best: 66kmpl Fuel Efficiency Worst: 52kmpl Range: 800kms Price Ex-showroom Delhi: Rs 85,040 Ex-showroom Delhi: Rs 50,000 Back this is just a bit of what you can find good luck and welcome
