yamaha enticer
Hi
Am in desperate need of some information regarding the Yamaha Enticer 125cc..... I have recently bought the bike with the intention of fixing it up as a bike to learn on,,, but i have found out the bike was made in India, and no one in the UK can give me any advice on parts, as most have never even heard of it. The bike has suffered some front end damage and new forks and wheel are needed...... Question..... Is there another bike that has the same fork measurements...
My yolk size is 30mm hole and 185mm centres, the yolk stem is also 30mm.
It may be possible to buy a complete front end from another bike if the stem is the same size,, i was told the virago xv 125 may be the same,, is this true?????
Any info however small may be of some use to me
Cheers
Terry
I would sugest possibly posting a couple pictures of it, as it may have been sold somewhere else under a different name. In the US a Yamaha Enticer was a snowmobile lol.
Hi
Cheers
Terry
yes the yamaha enticer is from india try googling it there is a lot of information out there
Type: Single cylinder 4 Stroke, air cooled
Displacement: 123.7cc
Max Power: 11bhp@8000rpm
Max Torque: 10.4Nm@6500rpm
Bore x Stroke: 54.0 x 54.0mm
Compression Ratio: 10:1
Power to weight: 94.83bhp/ton
Idle Speed: 1300-1500rpm
Carburettor: Ucal Mikuni VM20SS
Air filter: Wet type element
Oil Filter: Wire mesh type
Ignition: CDI
Starting: Kick
Clutch: Wet multi-plate
Gearbox: Four speed
Primary Reduction: 3.579:1
Final Reduction: 3.133:1
Gear Ratio kmph/1000rpm
1 2.750 3.658
2 1.688 5.959
3 1.200 8.383
4 0.913 11.018
Kerb Weight: 116kg
Max Payload: 130kg
Wheelbase: 1380mm
Length: 2090mm
Width: 790mm
Height: 1125mm
Ground Clearance: 140mm
Fuel Capacity: 13.5litres
Reserve: 2.5litres
Battery: 12V 2.5A
Headlamp: 12V 35/35W
Chassis: Diamond frame
Front Suspension: Telescopic fork
Rear Suspension: Swingarm with coil spring and oil damper
Tyres Front: 90/90 - 17" Front: 90/90 - 18" 4PR
Rear: 130/90 - 15" Rear: 120/80 - 16" 4PR
Brakes Front: 230mm discs Front: 130mm drums
Rear: 130mm drums Rear: 130mm drums
Performance 0-60kmph: 7.2sec 0-60kmph: 8.4sec
0-80kmph: 12.6sec 0-80kmph: 16.9sec
0-400meters: [email protected] 0-400meters: [email protected]
Roll On 3rd 4th 5th
30-70kmph 9.5 13.2 15.4
40-80kmph 9.9 13.4 15.9
Roll on 3rd 4th 5th
30-70kmph 11.1 16.1 -
Braking (60-0kmph): 23m/2.9sec
Top Speed: 97kmph
Fuel Efficiency Best: 66kmpl
Fuel Efficiency Worst: 52kmpl
Range: 800kms
Price Ex-showroom Delhi: Rs 85,040 Ex-showroom Delhi: Rs 50,000
Back
this is just a bit of what you can find good luck and welcome
