November 18, 200817 yr i have a Fzr1000 Exup. Makes a noise when under load. The chain was tight when bought. Can i remove bearing without poping pistons and rings?
November 18, 200817 yr Replacing the bearing on the sproket shaft. you should be able to stip the bottom case off and leave the head & cylinders insitu but I dont think your noise comes from that bearing, if it was well worn you would have a major oil leak there. explain more about this noise did it appear after the chain lost tension ? regards Jim
November 19, 200817 yr Author No it remained the same. The noise is heard even at 120KM/h. Oil is fine. It does get louder when going throught the gears exspecially from 3rd up. When driving and i close the trotle a bit it shuts up but when opening the noise starts again.
November 19, 200817 yr Replacing this bearing on the FZR1000 needs a full engine strip down, as there are bolts underneath the head that need removing to split the cases.
November 19, 200817 yr Replacing this bearing on the FZR1000 needs a full engine strip down, as there are bolts underneath the head that need removing to split the cases. cannot remember them ... but it was in 88 when I did the course... memory dims over time !!! but I guess the bearing is not at fault in the first place Regards Jim
November 19, 200817 yr Moderator I dont think your noise comes from that bearing, if it was well worn you would have a major oil leak there. explain more about this noise did it appear after the chain lost tension ? regards Jim +1 Sure the C+S are good, the rear wheel bearing would also be worth a look. I have seen these kind of threads soooooooooo many times and the C+S is generally the culprit.
November 19, 200817 yr +1 Sure the C+S are good, the rear wheel bearing would also be worth a look. I have seen these kind of threads soooooooooo many times and the C+S is generally the culprit. thats were I was going !!! it does sound like an external transmission noise regards Jim
November 21, 200817 yr Author The chain and sproket are a bit worn but can go a few miles. Will change that firste before stripping the case. Thanks alot people
