82/83 xs250 se special
Hiya Fellers, Can`t find the correct caliper,
Anyone know of an alternative that might do the job?,
Many thanks, Mark.
Many thanks, Mark.
is it the single piston caliper, or swinging caliper with the round brake pads?
Hiya drwepy, i was just about to send you a message,
YOU DA MAN, Removed pilot screws, well blunt, Got the wifes board thingy
for her nails and got "THE LOOK" you know the one, And proceeded ta sharpen
the needles, Worked a treat, (will replace as soon as), The needles not the board,
Still a bit erratic, but a lot better, need to ride her now, Can only be good for the
bike, not been on the road for a long long time, you certainly know your stuff,
Well now this bleeding caliper, It`s a single cylinder, And can swivel on the spindle that
threads all the way through, ie the caliper moves freely of the fork mounting, only a little way,
Pads not round,
Am i making any sense?,
Thanks for keeping in touch, All the best, Mark.
P.S. been trying to upload pics no joy.
For pictures Mark
  • Open a photobucket account
  • Upload your pics there
  • with each pic you will see four fields
  • Copy the IMG field
  • Paste into the forum
Thanks `oldgitonabike`, and here`s me thinking i was the only one, fun being old init,
I`ll give that a shot,
Pads not round,
not really, all calipers float but what I'm asking is does the mounting bolt go through the side or along in relation to the bike?
Sorry drewpy it`s been a long day, There`s two bolt`s that go through the mounting bar not the caliper to the fork,
Horizontally to the bike, And one other long bolt part of the mounting, that go`s through the caliper, that it swivels on
that run`s parallel to the fork,
I hope i`ve explained a little better, cheers mate, Mark.
I think so, what I am thinking is that Yamaha used parts bins so identifying the caliper will enable us to offer an alternative, but the same type of caliper.
I think a pikkie would be best
Hi mate, i`ve just been looking for your E mail address to send a pic (cant find it),
as i can`t upload to here yet, Thanks, mark.
Just had a thought, It`s the same as on a late 70`s model RD250 Any help?, Mark.
you can pm me with an attatchment!!
can you not use a rebuild kit? quite easy to do
No don`t think so drewpy,
Were the bleed nipple should be has been drilled out, (not very well),
and filled with some hard "gunk" i removed this, the hole is huge,
i`ve tried all sort`s to fix it, before i went the "sod it get another route",
Re taped, new nipples various size`s, you know the sort of thing,
I rarely give up easily,
Many thanks, Mark.
I PM'd you mine and offered to do this for you!
Thank you, I`ve sent two pics, i`ll send a close up in the morn, if i may,
I feel like Mr D`mill,
Cheers, Mark.
Here it is!!
one in usa which needs rebuilding.
Item number: 260315180697
new?
http://www.motogrid.com/pages/parts/viewby...95/default.aspx
CALIPER ASS'Y (SKU: 2V0-25810-00-00) 1 $240.80 -
new?
Thanks drewpy nice photo, At least i know what it is now,
Your a DIAMOND sir, Mark..
new?
Sorry me again, Whats usa? (needs building), Cheers mark,
usa, y'know uncle sam....America (The clue was in the dollar sign), yes you might even have to shop that far away unless youre lucky!
Thanks OG, feel like a right thicky now, Derr, Mark
Just about to post, First Ride,
