November 17, 200817 yr No mate, it won`t fit. I tried this last year, main problem is the area around the bars, you can`t get the bars to turn as the gap in the fairing is too small. It might fit with some major alterations, but then you lose the look of the OW01.
November 17, 200817 yr Author No mate, it won`t fit. I tried this last year, main problem is the area around the bars, you can`t get the bars to turn as the gap in the fairing is too small. It might fit with some major alterations, but then you lose the look of the OW01. Do the bars touch on the top of the fairing or would a set of aftermarket clipons work as these could be moved down Thanks gareth
November 18, 200817 yr If i remember right, they touched at the bottom. Also couldn`t turn the bars as they hit the front part of fairing.
