Posted November 15, 200816 yr hi there my dtr125 is leaking 2 strock out of the carb......is this normal or as something gone rong somewhere cheers
November 15, 200816 yr Moderator hi there my dtr125 is leaking 2 strock out of the carb......is this normal or as something gone rong somewhere cheers Doesnt sound right to me, where exactly is it coming from? usually theres a pipe from the pump that goes onto a spigot on the carb, are there any splits in this pipe? its not a good idea to ride until you sort this out!
November 15, 200816 yr Author Doesnt sound right to me, where exactly is it coming from? usually theres a pipe from the pump that goes onto a spigot on the carb, are there any splits in this pipe? its not a good idea to ride until you sort this out! it is coming out of the pipe on the left hand side of the carb mate............i have checked all the pipes around the carb and there is no splits and i have check the pipe from the 2 stroke pump and all ok..............The bike is of road now
November 15, 200816 yr Author i forgot to say it as loss i bit of power aswell.......as i can normal get about 68mph but now only get up to 60mph and thats at a push. not sure if this is due to the 2 stroke leak....
