November 14, 200817 yr Hi, I have a dt125 fully converted to offroad use, Is it normal for the float valve in the carb to get stuck if I leave the fuel tap on overnight? everytime it gets stuck i have to take the bike apart and drain the carb out. also i have tryed starting my bike up with fuel tap turned off to drain it, this doesnt work. Has anyone had this problem and found a solution please reply thanks. regards, Wes
November 14, 200817 yr Moderator This is a bit old school but i got myself into the habit of switching the petrol off before the engine whenever i switch the bike off, after the joys of draining the cases on my DT after i jacked it up 'a little'. The angle it sat at on the stand meant the floats rest on the side of the bowl and dont always close. It is something i always do now from habit. Total cost nowt.....
November 15, 200817 yr Author This is a bit old school but i got myself into the habit of switching the petrol off before the engine whenever i switch the bike off, after the joys of draining the cases on my DT after i jacked it up 'a little'. The angle it sat at on the stand meant the floats rest on the side of the bowl and dont always close. It is something i always do now from habit. Total cost nowt..... since i got a pitstand it doesnt get stuck even if i leave the petrol on. maybe the standard stand angle is a problem. thanks for your help guys
