November 8, 200817 yr As in the title has anyone got the correct float height for a ybr125 05 vm22 carb, cheers
November 8, 200817 yr HI Morgy The float height for the 05 YBR125 is 21.8mm measured from the float bowl gasket face (i.e gasket removed} to the bottom of the float. Also when checking make sure the tang of the float just touches the needle valve and doesn,t compress the spring inside the valve. Hope this helps. Tony.
November 9, 200817 yr Author HI Morgy The float height for the 05 YBR125 is 21.8mm measured from the float bowl gasket face (i.e gasket removed} to the bottom of the float. Also when checking make sure the tang of the float just touches the needle valve and doesn,t compress the spring inside the valve. Hope this helps. Tony. cheers Tony this helps alot, the more info the better, thanks again
November 9, 200817 yr Hi Morgy Just noticed in the manual they also list a fuel level of 6 to 7mm checked by connecting a piece of clear tube to the float bowl drain and undoing the float bowl drain screw with the fuel tap on and holding the tube next to the carb. The distance is measured from the horizontal line of the carb / floatbowl join to 6 to 7mm below the line with the bike level and upright. This is probably easier to check then having to take the carb off to check float height.Hope this helps.Tony.
