Diversion Restrictors
Does anyone know where I could get a restrictor kit for a diversion 600?
I've just passed my A2 and a friend can lend me a 600 to try out but only if I get the kit!
Would I be able to fit it myself or do you require the garage too?
Thanks for any help.
depends on how legal you want to be ! you could get washers with the same o/d as the inlet manifolds (rubbers) and drill the hole out to about 12mm (not to legal but 33hp would be close if put on a dyno) cost (aprox £4.00 + fitting) or buy the real kit @ £160 + fitting. At present I have restricted a FZR600 (water cooled - early Thundercat) to 33hp using the first method and the dyno showed 32.5 hp but I must admit the bike was not rideable and you would be better off finding a 33hp bike
Regards Jim
